LM317 Misfunction
Discussion in 'General Electronics Chat' started by Ravaner, Apr 7, 2008.
  1. Ravaner
    Apr 7, 2008
    12
    I used LM317 regulator in an adjustable power supply connected to a filament ( working under vacuum ). This circuit worked correctely for several weeks and now is dead. My printed circuit board has been checked and is OK. Normally this IC is thermaly protected and also protected against short circuit. Has someone met same kind of problems with this IC ?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No, they are usually very reliable. What kind of voltage and current was the filament using? Did the filament float on a high voltage? Was there a heat sink on the 317?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    I read somewhere that if an IC (voltage regulator or power amplifier) goes into thermal cutoff too many times then the thermal stress of heating and cooling over and over will kill it. They say to use a heatsink large enough to prevent too many thermal cutoffs.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    This sounds like a good time to look at the thermal stress to which the part is being subjected. If the part is not sufficiently heatsinked as beenthere and audioguru have pointed out, there is a high likelihood that it is being thermal cycled to death.
    hgmjr
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You do know there is a huge difference in the resistance of a cold filament and a hot one. Why on earth would you be using a regulated DC voltage on a filament. It doesn't sound like a very bright thing to do -- so to speak. In all the tube circuits I ever built I always used AC from a transformer on the filaments.
  6. Ravaner
    Apr 7, 2008
    12
    Many thanks for your answers. First my filament is installed in an homemade experimental apparatus ( mass spectrometer ) and not in a classic radio tube. Heat sink is large and always stays almost cold. When voltage (minimum one = 1.2 V ) is connected to filament, resistance increases and maximum current is in the order of 350 mA. I don't use any cap in parallel with filament and so I did'nt install any protection inversed diode ... I don't undestand why it works several weeks without any trouble. According to my calculation, even during switching on, transient current couldn't exceed 800 mA !
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What is the input voltage to the LM317? Do you have a cap across the input?
    Realize that the maximum power dissipation in the LM317 will occur when it's output is at the lowest voltage, which (coincidentally) is where your filament will pass its highest current due to its low (cold) resistance. As the filaments' temperature increases, so does its resistance.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The problem is almost certainly related to the current draw of the cold filament. One possible kludge to get around that is to use a switch to start up the filament from the DC supply through a resistor to limit current. When the filament has had a minute to so to warm up, flip the switch to the LM317 for regulating the filament current more accurately.
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    Years ago I had a project that used incandescent light bulbs but they needs to flash on and off with DC. They frequently burned out.
    I added resistors to keep them warm (but very dim) and then they lasted nearly forever.
    Try adding a resistor to keep the filament warm.
  10. kubeek
    Sep 20, 2005
    4,689
    806
    You could also use the LM317 as a current source, sourcing the current that is rated when the device is hot. That way you prevent high current peaks during warmup.
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What Audioguru suggests is a good "trick" that's tried and true.
    Texas Instruments called them "keep-alive resistors" in a 1980 linear control circuits databook, referencing the TL489C 5-step analog level detector.
    The datasheet link is below, the example is on the 3rd page of the .pdf (pg 347)
    http://www.tranzistoare.ro/datasheets/208/489266_DS.pdf
  12. Ravaner
    Apr 7, 2008
    12
    Many thanks for your answers and tricks. I've inserted a small value resistor in my filament circuit, and it works.
