LM317 basic switch mode supply
Discussion in 'General Electronics Chat' started by rbg5k, Jan 26, 2010.
  1. rbg5k
    Jan 26, 2010
    5
    You can set up an LM317 as a constant current supply with a simple power resistor between the output pin and adj pin to set current and take your CC output from the adj pin.
    Now, if I wanted to also have a switch mode (and constant current) supply, can I simply switch the input voltage on/off at the LM317 input?
    Say 100khz or so with an on/off pass transistor at the LM317 input?
    And I suppose a choke on the output?
  2. rbg5k
    Jan 26, 2010
    5
    I know there are other. more suitable parts designed for smps but I have a bunch of boards with Lm317 already that I'd like to utilize.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    There are a couple of schematics in National Semiconductor's datasheet for the LM117/LM317 on page 18. The "Low Cost 3A Switching Regulator" didn't simulate well; it just acted as a linear regulator.
    Didn't try simulating the 2nd one.
  4. studiot
    Nov 9, 2007
    5,005
    515
  5. rbg5k
    Jan 26, 2010
    5
    Ok thanks. I have a ton of lm317.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Perfect for LEDs then. :D Seriously, this is not a bad thing.
