Hi folks,
I know that an LM317, 317L in this case, will work well as a current limit but in order to do so it needs to drop circa 1.2V across the sense resistor.
See circuit A
What I would like to know is can I do something like circuit B to reduce the overall voltage drop whilst limiting is not active.
I have a small monolithic DC/DC converter with a maximum output of circa 160mA and want to protect it with but with the minimum voltage drop when the current is below Imax.
Any and all suggestions welcome
Al
See circuit A
Al
