LM317-10A-1.2 to 30 V power supply advices
Discussion in 'The Projects Forum' started by jm-a, Apr 10, 2016.
  1. jm-a
    Thread Starter Active Member
    Oct 20, 2010
    105
    Hi all,
    I only " translated " , a power supply schematic for an halogen lamp - 45 W , about 4A under 12V.
    In fact, i plan also to use it for more projects .
    http://electronics-diy.com/electronic_schematic.php?id=981
    It would be great, if someone could check my schematic copy.
    Of course, ( 15 * 1,414) - 2 is only 19,21 V .
    Thanks a lot.
    jm
  2. dannyf
    Sep 13, 2015
    2,196
    417
    It will output a voltage that varies slightly with varying load - in my book, that doesn't work as a regulator.
    It is very easy to check it yourself - read the datasheet.
    jm-a likes this.
  3. Dodgydave
    Jun 22, 2012
    5,134
    767
    your better using a Pnp series pass transistor, than npn.
    jm-a and Marcus2012 like this.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    As dd told you, better use a PNP transistor as pass transistor.
    This picture from the hamradio magazine " FUNK Amateur march 2016" shows you the effect of using the PNP pass transistor:
    Sorry for the german text, but the images are clear.
    Bertus
  5. eetech00
    Jun 8, 2013
    675
    115
    Hi
    You might consider using a step down (buck) controller with external switch.
    jm-a likes this.
  6. Marcus2012
    Member
    Feb 22, 2015
    349
    26
    I've seen that 7805 pass PNP diagram before in the datasheet for the 78xxs and I couldn't figure out why that PNP doesn't have a base resistor. It seemed a bit odd but I figured there was something I didn't understand.
    jm-a likes this.
  7. jm-a
    Oct 20, 2010
    105
    As usual, thanks a lot for your replies.
    Great site.
    jm
  8. ronv
    Nov 12, 2008
    3,392
    1,448
    I'm guessing your worried about the base current? The 317 acts as the base resistor. The circuit has no short circuit protection anymore as it is. You could add a little resistor in the base to current limit the transistor again.
