ok thanks!The strobe pin allows you to turn off the output stage.
If the strobe is low, the output transistor is in the OFF state; therefore the voltage level will float to whatever might be supplying current.dont what OFF here means.. if floating/disconnected OR just pulled to Gnd or Vee...
