LM311 : Balance, strobe & Vee pins.
Discussion in 'General Electronics Chat' started by IcedFruits, Apr 19, 2014.
  1. IcedFruits
    Jan 15, 2014
    84
    What are balance, strobe & Vee pins in LM311 ?
    balance & strobe pins seem to be used for offset (input voltage?) adjustment, but please explain their work in detail if possible.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    The strobe pin allows you to turn off the output stage.
    The balance pin are for canceling the DC-offset voltage.
    The Vee pin is use as a voltage supply pin because pin 1 (GND) can be used as a emitter output.
    IcedFruits likes this.
  3. IcedFruits
    Jan 15, 2014
    84
    ok. but, what if i want to use it just a basic comparator, do i leave all those 3 pins floating ?
    in this datasheet i think they mentioned to short strobe & balance pins when they are not necessary, is that the way to go ? what about Vee pin then, floating ?
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    Look at simplified diagram that I post last time.
    And notice that LM311 contains a op-amp ( a comparator) and additional NPN transistor (emitter at pin 1 and collector at pin 7).
    And comparator is supply from pins 8 and 4. And if you don't use balance pins, simply short together pin 6 with pin 5.
  5. IcedFruits
    Jan 15, 2014
    84
    ok, and that simplified upper right corner diagram tells me to short pins 1 & 4 to ground for single supply configuration. thanks.
