LM301AN substitute?
Discussion in 'Analog & Mixed-Signal Design' started by GodsmacK, Jul 4, 2016.
  1. GodsmacK
    Jun 18, 2016
    14
    Hello, I'm looking for an improvement or equivalent for the LM301AN because I'm making an oscillator but I gives me some distortion in the output waveform. Hope you can help me...
  2. hp1729
    Nov 23, 2015
    2,105
    235
    Some differences exist is offset and frequency compensation, but most op amps should work. It is hard to get specific without a schematic and waveforms you were getting.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    652
    Post a schematic and a picture of the distortion.
  4. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    I am thinking about 2N2955. What you say?
  5. DickCappels
    Aug 21, 2008
    2,777
    674
  6. dl324
    Mar 30, 2015
    3,379
    652
    I took @Techno Tronix's post as a sarcastic rejoinder to an ambiguous request for help...
    schmitt trigger likes this.
  7. GodsmacK
    Jun 18, 2016
    14
    I'm making this circuit, from which I get tunable frequency triangle waveform from U1 and a square from U2. I have no problems when simulating it.
    However, in real life, this is how the triangle waveform looks like with the LM301. Much distorsion and frequency doesnt change
    Yet, the square is good and I can tune it.
    PD. I used Hantek USB Oscilloscope.
  8. GopherT
    Nov 23, 2012
    6,320
    4,044
    @GodsmacK
    In real life, your OP amp is not perfectly balanced & compensated. That OP was designed before laser trimming was used. From the datasheet, there is information how to balance that op amp.
  9. DickCappels
    Aug 21, 2008
    2,777
    674
    The Thread Starter has another thread going on this forum, apparently about the same signal generator. Having more than one thread for a given topic is usually not allowed but since this thread is sticking to op-amp selection I will not close it, though other moderators might have different ideas.
    The URL of the earlier thread that continues to this time is provided below for context for this discussion.
    http://forum.allaboutcircuits.com/t...itude-function-generator.125115/#post-1015223
    GopherT likes this.
  10. schmitt trigger
    Jul 12, 2010
    46
    8
    You can get away by not using the compensation capacitor on the left-hand opamp which is operating as a comparator. But the second one which operates as a linear integrator, should have a compensation capacitor.
