LM2917 - 8 F/V Convertor!
Discussion in 'General Electronics Chat' started by lee1804, Dec 2, 2009.
  1. lee1804
    Dec 2, 2009
    Hi all,
    For pat of a college project building a closed loop feedback system on a small 12V conveyor.
    For the input i was going to connect a small metalic wheel to the motor of the conveyor, and use a proxy but this only gives a DC outout. Where the 8 pin LM2917 needs an AC input. The only reason i was going to use this proxy is because i happened to find one at work.
    Is there anyway to make this work, or a cheap / easy alterntive?
    the circuit im going to use is in page 8 of this datasheet:
    http://www.datasheetcatalog.org/datasheet2/0/01gcjjplyzka2uqqx3846g9ri17y.pdf
    Any help is much appriciated :)
    Thanks lee
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Can you post your schematic of what you intend to do?
