LM2907 Voltage Input
Discussion in 'General Electronics Chat' started by Tony Elliott, Jan 16, 2016.
  1. Tony Elliott
    May 8, 2015
    140
    Hi AllAboutCircuits,
    I am using a LM2907-N for a frequency to voltage circuit. I have looked at the data Sheet http://www.ti.com/lit/ds/symlink/lm2907-n.pdf
    I see the maximum voltage is 28 volts, but if I use a ( -15 ground +15 ) does that exceed the voltage as 30 volts. Should I use ( -13 ground +13 ) 26 volts?
    The circuit I am using is on page 15
    If you need any more information I will gladly post.
    Anthony
  2. ErnieM
    Apr 24, 2011
    7,447
    1,628
    The device is a single supply circuit, meaning you connect power between the +15V and ground.
    Since 15 V < 28 V your device is quite safe. :rolleyes:
  3. Tony Elliott
    May 8, 2015
    140
    So I don't need the - voltage, only ground and +? or do I use only - + ?
  4. GopherT
    Nov 23, 2012
    6,340
    4,094
    If you would use only + and -, then you still exceed 28 v.
    Use 15v from 0 to V+.
  5. ErnieM
    Apr 24, 2011
    7,447
    1,628
    Yes, just like the figure on page 15 of the data sheet.
  6. #12
    Nov 30, 2010
    16,705
    7,358
    Yes, just like the schematic you posted.
  7. Tony Elliott
    May 8, 2015
    140
    Thank you for your advice, yes I tried it today and it worked perfectly. :)
    ErnieM likes this.
