hi guys
i use a lm2577-adj for boost the voltage of a 1cell li-ion battery (3.8v-2600mah)
i use circuit that is in first page of lm-2577 datasheet and set voltage to 6.4 volt.
then i connet the circuit to four 1watt led's that i series each two of them and then parallel two strings.so for them i need 6.4 volt and 700ma current.(Pout=4.48)and P in should be about 3.8V*1.3A=4.94W
but when i connect the battery output voltage became to 5.5 volt and 200ma of current(Pout==1.1watt)
so what is problem?why voltage drop to 5.5 under load?
