I built a LM2576 via this tutorial http://www.ti.com/lit/ds/snvs107c/snvs107c.pdf. I used LM2576-5.0 because I need at output 5V and here is 3A max, but at output I placed USB connector I used 2 pins ground and 5V and cable USB -> microUSB (Raspberry Pi 5V/900mA approximately) all is going correctly without trouble. LM2576s schematic have at input 12V battery, but I need power a Arduino too (I can power arduino with 12V or 5V/500ma), but here is my question. 1.Can I power Arduino from battery before LM2576s schematic? something like this http://prntscr.com/1zkx4x, or 2. I used to power Arduino from output from LM2576s and here will use no 1 USB connector but 2 USB connectors something like this http://www.sos.sk/?str=371&artnum=40942&name=assmann-usb-bu2a-a-usb-a-2p...In both cases is it any types of influencing current?...or which solution is better? At 2 USB connectors I only need 4 pins 2GND 2 +5V, but can I combine?..Thanks
