I'm trying to design a small switching power supply. I found LM2575 in a nearby shop, and it seemed nice and easy.
However, I found 2 datasheets, one of them (THIS ONE) contains thorough step by step instructions on how to choose the components, and the other one (THIS ONE) has fixed values for the components.
Which datasheet should I use? Do those two work for the same chip, or the LM2575's from different manufacturers are different?
I'd like to reduce ripple as much as possible, so I'd rather use the first one if it works, so if someone knows...
