LM2575-5 help
Discussion in 'General Electronics Chat' started by Garurumon, Nov 26, 2013.
  1. Garurumon
    Mar 17, 2013
    99
    I'm building a little 5v breadboard supply, and I bought LM2575-5 switcher.
    However, I read somewhere that it won't operate very well on very low currents? Is that true? If yes, could that be fixed by adding a minimum load?
    Is this 52kHz switcher good (stable, low ripple) enough for powering micro controllers and digital stuff anyway?
  2. ronv
    Nov 12, 2008
    3,403
    1,477
    I don't see anything in the data sheet about minimum load, but 5 or 10 ma. might not hurt. Seems you could run a lot of logic with an amp.
    Garurumon likes this.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    It will have no problem at light load or no load. It may be dropping pulses so you might hear some noise. may be a shade higher output voltage ripple at no load, but will regulate properly.
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Add a LED (can be low current).
    uC will often need additional filtering coil. But you don't need additional large capacitors, 1uF or so will do.
  5. Garurumon
    Mar 17, 2013
    99
    Thanks to all of you...
    One more question, how is the ON/OFF pin (pin 5) used? Can I put a switch there to controll it?
  6. Metalmann
    Dec 8, 2012
    700
    223
  7. Garurumon
    Mar 17, 2013
    99
    Metalmann likes this.
