LM13700 VCO Design help
Discussion in 'Analog & Mixed-Signal Design' started by MachineHum, Jul 15, 2016.
  1. MachineHum
    Nov 3, 2014
    70
    Hey guys/girls,
    I'm designing a VCO using TI's LM13700 (Datasheet below)
    http://www.ti.com/lit/ds/symlink/lm13700.pdf
    On page 19 there is a pretty good looking schematic. Working the math is no issues, but all the formulas are using Ic and Ia, and to get these I need to know the voltage at the two points I've marked below. Obviously I can't assume their high impedance inputs because that would make the current zero.
    If anyone has an answer that would be very helpful, bonus points for resources to learn about TC amps.
    MH
  2. AlbertHall
    Jun 4, 2014
    2,275
    449
    From the data sheet, page 11:
    Next, set IBIAS. The Bias Input pins (pins 1 or 16), are 2 diode drops above the negative supply, and therefore
    VBIAS = 2(VBE) + V- , which for this application is -13.6 V. To set IBIAS to 1ma when VC = 15 V requires a 28.6-kΩ;
    30-kΩ is a standard value and is used for this application. The gain will be linear with the applied voltage.
    GopherT and MachineHum like this.
  3. atferrari
    Jan 6, 2004
    2,668
    784
    Hola Albert,
    You can claim his bonus points as yours.
  4. MachineHum
    Nov 3, 2014
    70
    Thanks Albert, much appreciated :)
