Lm 386 problem..........
Discussion in 'The Projects Forum' started by Bob T., Oct 23, 2012.
Lm 386 PCB problem?
Poll closed Oct 28, 2012.
  1. My lm 386 circuit is producing wierd sound.
    100.0%
  2. LM 386 is niosy.
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Bob T.
    Oct 22, 2012
    35
    Hello and piece........:)
    I foud this circuit on the internet and acording to my experience in electronics i see that i must work, so i transferred this to EAGLE and made a PCB for it, but when i connect a 9V (not from batt.) it started to produce weird sounds like a 555 time connected to a speaker and when i change the volume (potentiometer) the frequncy of the pulses changerd like 555 timer, but i barely could hear my vioce amplified.
    What i sould to to fix my PCB?
    Pleaze help!!!........:(
    If anybody wants the EAGLE file i am ready to send, but give me your mail.
    Thank you all................;)
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    I see no decoupling capacitors in the given circuit.
    Decoupling or Bypass Capacitors, Why?
    You could try an capacitor of 10 - 100 μF and a 0.1 μF parallel on the pins 4 and 6 of the LM386.
    Bertus
    Bob T. likes this.
  3. absf
    Dec 29, 2010
    1,493
    374
    As you said you didnt use battery, did you try putting a 220uF across pin 4 & 6 of the LM386?
    Allen
    Bob T. likes this.
  4. atferrari
    Jan 6, 2004
    2,674
    785
    Why a poll? It makes no sense.
    shortbus and Bob T. like this.
  5. Bob T.
    Oct 22, 2012
    35
    Tank you.
    This is the first time to me and I don't know what are polls....
    I will try the decoupling cap, should use bypass caps?
    Shall I use a battery?
  6. tracecom
    Apr 16, 2010
    3,884
    1,396
    I would try a battery first to ensure that the problem is because of the power supply. Then, I would condition the output from the power supply and use it.
    Bob T. likes this.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    If the micriphone can hear the speaker then it will produce acoustical feedback howling as a sound goes around and around. When the volume control is turned down then the feedback howling will stop.
    Try it with the speaker in another room with the door shut.
    Bob T. likes this.
  8. Bob T.
    Oct 22, 2012
    35
    I Hello, thanks to all.
    I added some decoupling capacitors every thing worker fine and clear.But when
    i boxed it in a project box is stopped producing any sounds , not even nois.
    And when i shorted pin 5 and 6 together i amplified sounds but the ic became hot
    and the sound was unclear, so whats the problem and can i fix it?
    Thanks.....
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    The datasheet shows that pin6 is the positive power supply pin and pin 5 is the output pin.
    You should NEVER short the output of a power amplifier to its power supply.
    You probably destroyed the IC.
  10. crutschow
    Mar 14, 2008
    13,527
    3,393
    Why would you short pins 5 and 6 together? :confused:
  11. Bob T.
    Oct 22, 2012
    35
    It was working good when i shorted 6 and 5, but became hot.
    i just heared sound when i shorted them?!.....
  12. atferrari
    Jan 6, 2004
    2,674
    785
    Was it The swang song?
  13. Bob T.
    Oct 22, 2012
    35
    I shorted it but not damage it, i still works.....
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    does the LM386 work properly when it is connected properly?
  15. Bob T.
    Oct 22, 2012
    35
    It is highly related to the passive components out.....and connections......
    Can any body Help me please i still don't know what to do......
    i think it is from a capacitor
  16. Audioguru
    Dec 20, 2007
    9,411
    896
    You shorted the output to the positive power supply so the LM386 is probably blown up.
    Simply fix the wiring and replace the LM386 IC.
  17. Bob T.
    Oct 22, 2012
    35
    I just wanted to see what will hapen..........I need any body to help me pleaze...I dont know waht the hell is happening in this circuit, it is just like....dead....Thank you.
  18. JoeJester
    Apr 26, 2005
    3,403
    1,230
    How did you reach that conclusion? What tests have you done to confirm the LM386 is ok?
    How did you reach that conclusion? What tests have you done to confirm the the passive components caused the problem?
    And what did you conclude after you shorted those terminals?
