LM 386 problem
Discussion in 'The Projects Forum' started by ashbury04, May 20, 2010.
  1. ashbury04
    May 20, 2010
    I am trying to install a LM386 amplifier in my car. the power to the amp is supplied by the car battery but when I connect the circuit ground to the chasis the amplifier stops working.Anyone has any idea how to solvethis problem? thanks
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    That's it?
    How about a schematic as to precisely what you have connected up to it?
    Otherwise, we could guess for a long time and never figure it out.
  3. retched
    Dec 5, 2009
    5,201
    313
    It works before you hook the ground to the chassis?
    Is the area to the chassis you are connecting the ground to BARE metal and clean?
    If there is paint between the ground wire and the chassis, no dice.
    If you have a good ground, re-read Sgt.Wookies post.
