lm 338 ic is not providing more than 1 amp current!!!!
Discussion in 'General Electronics Chat' started by jigisha, Dec 19, 2015.
  1. jigisha
    Dec 19, 2015
    6
    Hii....
    I am using lm338 ic to-220 package used to provide 5v , 1.5 amp output.........i am giving power form my variable power source........nd had mounted one input electrolite cap 1000uf-25V, and and one 0.1uf ceramic cap at input , and providing 100uf - 25v cap at out. ..nd providing 220ohm resistor at ouput to adj pin terminal....and variableof 22k at adj teminal...by varying this pot i can get 5volt.........bt output current is not going more than 1amp........ plz suggest m wt should i change!!!!!! nd using proper heatsink with ic 338....................:(
  2. atferrari
    Jan 6, 2004
    2,674
    785
    Use capitals, stop pressing that "." key more than needed and post a schematic.
    spinnaker likes this.
  3. ISB123
    May 21, 2014
    1,240
    531
    Current is determined by the load.
  4. Veracohr
    Jan 3, 2011
    561
    77
    What is your input voltage?
  5. jigisha
    Dec 19, 2015
    6
    i am giving 16v from my variable power source.
  6. Alec_t
    Sep 17, 2013
    5,980
    1,138
    What is the rated current your power supply can provide?
  7. jigisha
    Dec 19, 2015
    6
    my supply can provide upto 20amp of current.....
  8. Dodgydave
    Jun 22, 2012
    5,172
    778
    Change the 220 ohm to 120 ohm, and use a 470 ohms preset pot.
    Post pictures
  9. GopherT
    Nov 23, 2012
    6,340
    4,094
    So, think about this, my friend.
    You are asking that LM338 to take 16V down to 5 volts (11 volt drop) at more than one amp. Since it is cutting out at 1 amp, that means you are getting thermal shutdown because your "proper heat sink" cannot dissipate 11 watts of power (11 volts @ 1 amp). You actually want 1.5 amps, 16.5 watts - a good sized heat sink will be required and good bonding to the heat sink.
    absf likes this.
  10. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Seven posts later and you are still using those obnoxious periods, no capital letters. Lots of old people here we don't handle "texting" speak well.
    And you still haven't posted a schematic. How do you expect your problem to be able to be understood?
  11. MikeML
    Oct 2, 2009
    5,451
    1,066
    Heatsink................. Heatsink................. Heatsink................. Heatsink.................
    actually, lack thereof...
    (16-5)V*1.5A = 16.5W
    To keep the temperature inside of the TO220 <100°C, the total thermal resistance Θja from Junction to Ambient must be (100-25) °C/16.5W = 4.54 °C/W.
    Since Θjc= 1°C/W, the Θhs bust be less than ~3°C/W.
    Even large finned heatsinks (Like These) require forced air cooling (fan) to get rid of that much heat.
  12. spinnaker
    Oct 29, 2009
    5,115
    1,195
    LOL
    I see you are posting in the SP's native language. Very kind of you.
