Hello
I am experimenting with LM2576 HV to convert 48 VDC to 15 Volt.
Circuit is working well. But when batteries are under charge Vin approaches 55 Volt (regulated by a PWM Morningstar microcontrolled device). That is dangerously close to 60 V, the max Vin rated.
So a couple of times The 2576 burned out. Both tries the circuit lasted more than a month, working 24/24.
I can reduce the input V connecting some diodes in series, and sacrificing efficiency.
But I suppose there are better solutions. I browsed for higher voltage ICs, but did not find.
Output C is standard electrolytic, not ESR. Can that harm ?
Thanks for your time !
Kind regards, Horacio
