lm 1875 amp problem
Discussion in 'The Projects Forum' started by TIP31, Dec 14, 2014.
  1. TIP31
    Aug 17, 2013
    25
    I need help with an amp using an lm1875. I am using a 15 volt wall wart as a power supply. But i am getting 6 volts of dc through my speaker. Below is the schematic I am using. I forgot to order a 220k resistor for the one near the ic so I had to use a 22k. Could that be the reason? 20141211_171939.jpg
  2. MrChips
    Oct 2, 2009
    12,625
    3,451
    You are using single supply at 15VDC, correct? Then you cannot directly couple the speaker to the amplifier. Put a 2200-4700uF capacitor in series with the loudspeaker.
  3. Lestraveled
    May 19, 2014
    1,957
    1,218
    MrChips pretty much nailed the reason you are getting 6 volts across your speaker.
    The 220K resistor you replaced with a 22K will lower the gain of the amplifier by a factor of ten.
  4. TIP31
    Aug 17, 2013
    25
    Like this? Or do I need to switch the polarity?
  5. TIP31
    Aug 17, 2013
    25
    Thank you for explaining the resistor les. I was wondering why it was a little quiet.
  6. MrChips
    Oct 2, 2009
    12,625
    3,451
    You need to switch polarity. Negative lead of the capacitor goes towards the loudspeaker.
  7. TIP31
    Aug 17, 2013
    25
    That's what I meant. And does it matter which cap I use? I have both a 4700 uf and a 2200uf.
  8. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    When I look at your last picture, it looks like you are connecting the speaker to pin 1.
    Pin 1 is one of the inputs of the amplifier, pin 4 is the output.
    See this example schematic from the datasheet:
    Bertus
  9. TIP31
    Aug 17, 2013
    25
    No I have pin one as input and pin 4 is output.
  10. MrChips
    Oct 2, 2009
    12,625
    3,451
    Try both of them and listen to the bass response. If the 2200μF cap sounds good to you then go with that. You can even compare it with a 1000μF cap.
  11. TIP31
    Aug 17, 2013
    25
    I'm wanting to make a 3 band eq for high mid and low. How should I go about putting that in there? Also I am putting an lm386n pre amp on it.
  12. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    A LM386 is not a preamplifier.
    It is an 1 - 3 Watt power amplifier, depending on the model.
    If you are looking for a 3 band tone regulation, have a look at the following schematic:
    Bertus
  13. TIP31
    Aug 17, 2013
    25
    Thanks and what would be a good ic for a pre amp?
  14. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Do we need to present everything on a golden platter?
    A quick search on this forum will give you this:
    Op Amps
    Bertus
