LM 13600 Voltage controled low pass filter
Discussion in 'Homework Help' started by Stanislav Maťa, Jan 5, 2016.
  1. Stanislav Maťa
    Jan 5, 2016
    I have homework to do LM13600 Voltage controlled low pass filter. I draw circuit in microcap and i think i have it correct. But in simulation i have strange data. Can you help me? :) I up circuit and image with simulation.
  2. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    Can you post your schematic as a .png or .jpg file?
    I can not read the .cir file.
    Here is the low-pass filter schematic from the datasheet:
    Bertus
  3. Stanislav Maťa
    Jan 5, 2016
    Yep here is it... :)
    I do this circuit according your schematic that you post.
  4. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    That is odd. Your schematic shows a chip with 12 pins.
    The LM13600 has 16 pins.
    Are you sure you are using the correct chip.
    Bertus
  5. Stanislav Maťa
    Jan 5, 2016
    Yes its correct, because you are using on low pass only one half of chip. Its a second chip on the picture.. :)
  6. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    You have the bias on pin 5 in stead of pin 1.
    Bertus
