little question
Discussion in 'Homework Help' started by Musab, Sep 20, 2008.
  1. Musab
    Sep 20, 2008
    25
    in a simple resistors circuit, why the measured value is always slightly less than the calculated value ?
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    When you measure inside a circuit, it can be that other components are parallel to the resistor so the value you measure is lower.
    Greetings,
    Bertus
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    The best way to measure the value of a resistor that is part of a circuit is to lift or otherwise disconnect the resistor at one end and then measure it.
    hgmjr
  4. Musab
    Sep 20, 2008
    25
    but even if there are no other components. Just resistors in series or parallel, the value is still slightly less
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Often there is a sneak current path around the resistor being measured. By disconnecting one end you can insure that the only current path seen by the meter is through the resistor being measured.
    hgmjr
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    Are you pressing with your fingers to hold the resistor to measure ?
    This can also lead to a lower value.
    Greetings,
    Bertus
  7. Musab
    Sep 20, 2008
    25
    thx
    @bertus why will that happen ?
  8. scubasteve_911
    Dec 27, 2007
    1,202
    resistance of your finger/body in parallel with the measured resistor
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    The phenomenon being referred to by scubasteve_911 becomes more pronounced as the value of the resistor being measured increases.
    hgmjr
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Perhaps the meter is inaccurate.
  11. jtolcou
    Nov 1, 2008
    The resisitor should have one leg removed from the circuit and use alligatoe clips when making measurements to eliminate your body's resitance.
