I think so, or start higher and use 4MHz, the values are up to you, play around until you get something you are happy with.they look nice! but then I would have to set my Fosc at 2Mhz to accomodate the *200* one, correct?
I think so, works for me, should work on Excel, but I'm using different spreadsheet software, so can't check.I tried that *retlw* but not working...you sure you typed it well
I think so, the only thing in there that could change is the lowest two bits of duty cycle and they aren't going to make much difference to the sound.Also possible to have only one CCP1CON for all these frequencies at 2Mhz?
Here's are the 32 freq Ima use! Now I don't care about musical notes but rather 32 different s*o*u*n*d*s and I don't care if they sound like music from planet *Mars* as long as they are different!Can you post the exact frequency of the thirty two tones you're trying to produce so that I can post an NCO (numerically controlled oscillator) example for you, please?
Cheerful regards, Mike
by Jake Hertz
by Duane Benson
by Aaron Carman
by Jake Hertz
