little pwm - adc quest
Discussion in 'Embedded Systems and Microcontrollers' started by Eric007, Sep 4, 2012.
  1. Eric007
    Thread Starter Senior Member
    Aug 5, 2011
    1,056
    33
    hi All
    Attached is columns of frequencies and PR2 values
    I initially set my Fosc at 8MHz...and tried computing corresponding PR2 value and realized that the first 10 PR2 values (at 8Mhz) are greater than 255. And adjusting the TMR2 prescaler is not helping...(best prescaler value is 16!!)
    So I decided to set my Fosc at 4Mz, good idea, right?
    As for the adc...I might have a quest that why I already included that in my title.
    thanks!
  2. Eric007
    Aug 5, 2011
    1,056
    33
    Oh just realised I also have a problem with the first 3 values for 4Mhz...
    Everything would work OK with Fosc = 2Mhz but I think this is too slow!!!
    Another solution would be choosing freq. values from 246.94 at 4Mhz, correct?
  3. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Seems you want to make some musical notes using the PWM. I make note of that fact as some people may not recognize the pattern of frequencies in your attachment, and you never stated your ultimate goal.
    I've always found it best to work these things out in Excel (not with pictures in Word). The int() function helps keep it real.
  4. Eric007
    Aug 5, 2011
    1,056
    33
    Yes you are correct Sir!
    Actually this thread is the continuation of my thread *sound circuit resistor* from the electronic chat forum but as i am dealing with coding now I decided to create another thread in this forum!
    I have worked these values with Excel but apparently there's no format for excel in the attachment windows...so I copied those values into word so I could be able to attach.
    yes It about music with PWM...I am currently writing a code...I'll be more explicit of what I trying to do in the next posts!
    BTW, I got those notes from here: http://www.intmath.com/trigonometric-graphs/music.php
    Thanks for your comment!
  5. Markd77
    Sep 7, 2009
    2,803
    594
    I can't open the attachment. Normally the Linux document editor works on Word files, but not that one.
    I'd also recommend using a spreadsheet, saves a lot of typing.
  6. Eric007
    Aug 5, 2011
    1,056
    33
    ErnieM was able to open it...why can't you open it? I've saved it for Ms Word 97 - 2003. maybe I should re - attached it again...
  7. Markd77
    Sep 7, 2009
    2,803
    594
    Tables are a bit of a pain, you have to add the "|" character to the end of each cell (but that can be done with a formula) and then copy and paste, select the text and click the table icon in advanced reply mode. Probably easier to save as .csv which everyone can view.
    Anyway it looks like this:
    How it looks in the post:
    [table=NOHEAD]QTY | Newark PART # | DESCRIPTION | UNIT COST | TOTAL COST|
    3| 93K5434 | PCB mount 12V relay | $ 2.28 | $ 6.84|
    2| 26R4228 | RESISTOR, METAL GLAZE, 20 MOHM, 500 MW, ± 5% | $ 0.12 | $ 0.24|
    1| 96M9178 | 12V wall wart p/s | $ 13.53 | $ 13.53|
    10| 70R0064 | TERM BLK, PCB, SCREW, 5.0MM, 2WAY | $ 0.73 | $ 7.30|
    1| 13T9276 | Enclosure for the Arduino Duemilanove or Mega | $ 9.46 | $ 9.46|
    1| 13T9277 | ARDUINO UNO Board w/ Workshop Starter Kit (just buy the 25$ arduino, not the kit) | $ 71.38 | $ 71.38|
    2| 13T9280 | PROTOTYPE BOARD FOR ARDUINO UNO | $ 10.42 | $ 20.84|
    3| 89K1072 | TIP120 DARLINGTON TRANSISTOR, NPN, 60V, TO-220| $ 0.43 | $ 1.29|
    1| 01M7886 | CONVERTER, DC/DC, 1.5W, +1000V | $ 183.00 | $ 183.00|
    1| 31K7040 | OPTOCOUPLER, DARLINGTON, 3750VRMS | $ 7.02 | $ 7.02| [/table]
    The result:
    QTY Newark PART # DESCRIPTION UNIT COST TOTAL COST
    3 93K5434 PCB mount 12V relay $ 2.28 $ 6.84
    2 26R4228 RESISTOR, METAL GLAZE, 20 MOHM, 500 MW, ± 5% $ 0.12 $ 0.24
    1 96M9178 12V wall wart p/s $ 13.53 $ 13.53
    10 70R0064 TERM BLK, PCB, SCREW, 5.0MM, 2WAY $ 0.73 $ 7.30
    1 13T9276 Enclosure for the Arduino Duemilanove or Mega $ 9.46 $ 9.46
    1 13T9277 ARDUINO UNO Board w/ Workshop Starter Kit (just buy the 25$ arduino, not the kit) $ 71.38 $ 71.38
    2 13T9280 PROTOTYPE BOARD FOR ARDUINO UNO $ 10.42 $ 20.84
    3 89K1072 TIP120 DARLINGTON TRANSISTOR, NPN, 60V, TO-220 $ 0.43 $ 1.29
    1 01M7886 CONVERTER, DC/DC, 1.5W, +1000V $ 183.00 $ 183.00
    1 31K7040 OPTOCOUPLER, DARLINGTON, 3750VRMS $ 7.02 $ 7.02
  8. Markd77
    Sep 7, 2009
    2,803
    594
    It's just because I don't use Windows. Ubuntu opens most Word files OK, but that one just looks like a blank page to me. A lot of nerds use Linux so if possible go for a universal format like .csv.
  9. Eric007
    Aug 5, 2011
    1,056
    33
    I've uploaded an edited version of the table in a pdf
  10. Markd77
    Sep 7, 2009
    2,803
    594
    Thanks, it looks like you have to start at a slightly higher frequency if you are going to use the PWM module. I don't think it's going to sound very much like a scale at the top end. It might be worth putting a column in for percentage error and seeing how bad it is. You could put the PR2 values for a different prescaler in the table for the higher frequencies, and then change the prescaler according to the table position. That would give better accuracy at high frequencies.
  11. ErnieM
    Apr 24, 2011
    7,443
    1,628
    I played around with the numbers some. Seems the highest frequency you can clock this is 3.39MHz: at 4MHz you loose the lowest 3 notes.
    You can gain a little accuracy if you cut back the divider for anything above about 880Hz, as this gives some range back into the PR2 number (makes it larger).
    Excel worksheet & cvs attached in the zip.
    Eric007 likes this.
  12. Eric007
    Aug 5, 2011
    1,056
    33
    I was going to post on what i been working on...and I have seen this post!
    Yes, that's correct the first 3 notes get lost at 4Mhz...that why I tarted with 246.94Hz to make my life easier...
    I had a look at your numbers...BUT you CAN'T set your internal oscillator at 3.39 Mhz...and I don't want to work with 2MHz Fosc.
    would you mind working with 2MHz Fosc?
    I think I'll just start from 246.94Hz
    Thanks again!
  13. Markd77
    Sep 7, 2009
    2,803
    594
    You can change the processor frequency and prescaler values in ErnieM's spreadsheet and it recalculates everything.
  14. Eric007
    Aug 5, 2011
    1,056
    33
    So I' ll just keep my original spreadsheet! I have added a column with CCPR1L:CCP1CON<5:4> that I will post soon but I have a quest in da mean time!
  15. Eric007
    Aug 5, 2011
    1,056
    33
    I am a bit confused about one thing...
    I am configuring my PWM as single output, P1A modulated...(PIC16F690)
    So I set the RC5/CCP1/P1A as output (TRISC,5 value) as it has to generate an output (wave) at that pin...but when I read the datasheet on page 129. section:11.3.12 I get a bit confused although I have used PWM before...:)
    my confusion comes from point 1. and 9.
    It's like initially that pin needs to be set as input then later as output, is that so? I don't really see the point here. it's like that pineeds to be set as input BUT when it is time to generate the waveform, it as to be set as output, correct? and if so why not just leave it as output?
    Hope I expressed my concern clearly and hope to be clarified on this one...
    thanks
  16. Eric007
    Aug 5, 2011
    1,056
    33
    I wasted too much time trying to figure out how to use that little duty cycle formula...lol :D finally figured out and came up with the following as attached.
    So I think Im correct to say that for each frequency,there's going to be different CCP1CON, CCPR1L values but same T2CON just that I'll have to turn it on and off...
    I am going to complete the code and post it for correction if any illogical thinking or whatsoever
  17. Markd77
    Sep 7, 2009
    2,803
    594
    Just for fun I worked out the errors for doing it without using the PWM module. It needs a 16 bit value so doubles the size of the lookup table and could use Timer1 interrupts. The minimum frequency would be under 20Hz.
    (This is for 4MHz clock speed).
    Eric007 likes this.
  18. Eric007
    Aug 5, 2011
    1,056
    33
    BTW, what's the difference between frequency and actual frequency?
    and what's the error really represents? I think I miss this point!
  19. Markd77
    Sep 7, 2009
    2,803
    594
    Frequency is the desired note, actual frequency is what the PIC would output. Error is the difference between them.
    I'm not actually sure how much error is OK, but the difference between two semitones (1/12 octave) is about 6% so I think even 1% error might sound quite sharp or flat.
    I just noticed that there may be missing notes from some of the tables, I'd expect to see either 8 or 12 notes per octave.
  20. Eric007
    Aug 5, 2011
    1,056
    33
    Yes you are correct!
    There are some missing notes from the table...I just chose some in order to have *thirty two* sounds in that *range* (2 hundreds to 3 thousands Herz)
