little algorithm code implementation!
Eric007
Joined Aug 5, 2011
1,158
Hi All,
I am writing a code for the following algorithm:
b7 = g7
b6 = b7 xor g6
b5 = b6 xor g5
b0 = b1 xor g0
In the above, assuming g7 - g0 is in Wreg initially!
I came up with the following code as attached!
I posted it here coz I NEVER took the time to learn how to simulate codes with MPlab Sim...(I'll try reading on it so I won't post such thang nomore).
As you can notice there is a repetition of a block of code...if the logic is ok, I will turn that block into a macro in order to reduce the number instruction cycles.
BTW, I was tipsy when writing this code so if....yeah...
All comments/critics are welcomed!
Markd77
Joined Sep 7, 2009
2,806
I might not be understanding, but can't you do it all in one go?
move W to temp
clear carry
rotate right the b byte
xor it with temp
job done
<ed> I flipped bit 7, just xor the result with b'10000000' </ed>
<ed2> Actually maybe I didn't </ed2>
BMorse
Joined Sep 26, 2009
2,675
move W to temp
clear carry
xor it with temp
job done
To convert binary to Gray, it is only necessary to XOR the original unsigned binary with a copy of itself that has been right shifted one place. I believe he is converting gray to binary here......to convert Gray to binary is to XOR the bits one at a time, starting with the two highest bits, using the newly calculated bit in the next XOR.
Eric007
Joined Aug 5, 2011
1,158
move W to temp
clear carry
xor it with temp
job done
No! You can't do it in one go!
Look again at the algorithm...the output of the next bit depends on the output of the previous bit and the current input bit...
Hope it makes sense what I just said coz I'm so drunk!
Doing it the way you suggested is the following algo:
g7 = b7
g6 = b7 xor b6
g5 = b6 xor b5
go = b1 xor bo
WBahn
Joined Mar 31, 2012
30,060
Then go sober up and come back when sober and first answer the question in which you were asked to give some clue as to what you are trying to accomplish. Specifically, are you trying to convert from a traditional reflected Gray code to binary?
Eric007
Joined Aug 5, 2011
1,158
Ok! I am sober now...:D
What I'm trying to accomplish is to translate that algorithm I showed I post #1!
And some members here have figured out what the algo is about...
I just want to make sure if the code correctly translates the algo coz I simulated it with a pencil and a piece od paper and I am conviced that it is perfect!
But I wanted an opinion from someone else like if it well coded!
Like I said the block of code that repeats itself will be converted into a macro so that instead of having that block, I'll just have a single line of code.
But there might be a simpler way to implement that block...
Anyways I am sure it would work without have the data corrupted!
WBahn
Joined Mar 31, 2012
30,060
But why did you feel that people needed to figure out what your algorithm does? Why could you start off with, perhaps, "I've developed an algorithm to convert from Gray code to binary. Could you please look it over?"
It can be done in shorter time. Consider the following C code:
binary = graycode;
binary ^= binary >> 1;
binary ^= binary >> 2;
binary ^= binary >> 4;
That converts an 8-bit Gray code to binary.
For why it works, see Gray Codes
Eric007
Joined Aug 5, 2011
1,158
@WBahn: I am sorry about that!
The reason I did that is because I did not want to implement other algorithm that does the same job BUT the one I showed only! and if I had said what I need to achieve we ll be throwing other algorithms...so to avoid that I did this
sorry errbody!
It ok I will have a look at you algorithm as it seems less complex
Thanks!
Eric007
Joined Aug 5, 2011
1,158
binary = graycode;
Yes Sir! this is beatiful...:D
Thanks so much...I been wasting my time for nuttin'
Check out the code attached! Any bugs in that code? No!;)
Thanks again!
Markd77
Joined Sep 7, 2009
2,806
You can save a few more cycles if you use swapf instead of the last four rotates.
Actually there are bugs,
Rich (BB code):
    clrc                ; clear carry flag
    rrf    temp, w            ;
    rrf    temp, w
actually only rotates by one bit, not two.
Eric007
Joined Aug 5, 2011
1,158
yep but swap alone would not work!
will have to add andlw 0x0F otherwise the result will be wrong and again this will result in 2 instruction cycles! but if I make it a macro like I showed in the attachment....I would be able to do the 4 (2, ...) rotates in a single instruction cycle. am I correct?
thanks Markd77
Eric007
Joined Aug 5, 2011
1,158
will this macro work?
Rich (BB code):
rrn    macro   freg1, freg2, literal
movlw   literal
movwf  freg2
clrc
rrf      freg1, w
decfsz   freg2, f
goto      $-3
endm
Markd77
Joined Sep 7, 2009
2,806
A macro doesn't save any instruction cycles. It takes exactly as long as the instructions as it contains.
Also look again at my last post, you still have bugs.
Eric007
Joined Aug 5, 2011
1,158
ok! I thought a macro would save the instruction cycles...
I thought that for instance " rrn temp, count, 4" would count as a single instruction cycle! I can't find any bugs...can you show me?
Eric007
Joined Aug 5, 2011
1,158
Stupid me! it should be " rrf freg1, f", right? u are talking about the macro, right?
too late! I am already late!
Markd77
Joined Sep 7, 2009
2,806
Partly, but that changes freg1, and you also want to keep it unaltered, so you probably need to copy it to a temporary variable.
It applies to the macro and also "version2.txt"
Eric007
Joined Aug 5, 2011
1,158
Thanks! that's an easy fix!
This is what happens when you mix Hennessy and Assembly...resulting in Chemistry!
