Lithium ion cells failure mode from overvoltage...
Discussion in 'General Electronics Chat' started by Externet, Jul 7, 2015.
  1. Externet
    Thread Starter AAC Fanatic!
    Nov 29, 2005
    775
    57
    Hi.
    The charge regulation voltage failed and applied about 5 Volts to several 16850 paralleled cells. All kaput. Did it create an irreversible chemical reaction with not a chance of recovery, right ?
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Probably lucky you didn't have a fire.
    Not sure it's worth thinking "can I fix these" as they might now be unreliable in some way and future fire risk could be a concern.
    I've never had a fire with a battery but then I've never abused one, I do know there's always been a general suggestion that charging problems can cause problems.
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,845
    1,313
    If the Li-ion batteries are incorporated in a 'pack' their apparent failure may owe to an open thermal 'fuse' -- otherwise they're probably "beyond the vale" --- I concur with Post #2 as regards safety/reliability concerns attendant to 'resurrected' cells...
    Best regards
    HP
    PS -- Why on earth do you wish to abolish the decibel???:confused:
  4. kubeek
    Sep 20, 2005
    4,688
    806
    That depends if the cells have internal protection circuitry or not. But either way they are probably toast.
