Lissajous figures
Discussion in 'General Electronics Chat' started by 76nemo, Sep 14, 2009.
  1. 76nemo
    Aug 2, 2008
    14
    I need help.
    I made a decade box to hook up to a scope to use as a curve tracer years ago to view lissajous figures. I can NOT for the life of me remember how to set up a scope to get this. I went to using a Huntron 2700 and got spoiled by it. I haven't set my box up to a scope in years.
    Can someone help me out???
    Much thanks in advance!!!!!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You have to be able to run in X - Y mode. I always drove the horizontal with a sine wave from my signal generator, and applied the other signal to the vertical. Black Sabbath or organ music looks pretty good.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    One thing, your scope must have an X-Y trace mode. Does your target scope have this feature?
    Beenthere got there ahead of me with the same comment.
    hgmjr
  4. 76nemo
    Aug 2, 2008
    14
    Yes, one of my scopes does.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Use that one.
  6. 76nemo
    Aug 2, 2008
    14
    Everyone at my new job is clueless to lissajous figures. I got spoiled with the Huntron at my old job. I could pinpoint problems very quick with it. I still have my decade box, I can't remember how to set up the darn scope to it. I have since gone into electrical work. I haven't used one in years, my box and a scope anyhow. I really appreciate your help guys/gals!!!!!!
  7. 76nemo
    Aug 2, 2008
    14
    I tried that and the figures were 90 degrees off. It's an old Tek scope and I can't remember the settings.......:rolleyes:
  8. 76nemo
    Aug 2, 2008
    14
    Phone break, be right back......
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If they're 90° off, just swap the X and Y inputs.
    If they're then 180° off, invert one of the channels.
  10. 76nemo
    Aug 2, 2008
    14
    I don't remember my old scope having XY. I have had a Fluke 123 for awhile which does not have A vs. B and I thought it could still be used with my box. I haven't worked on a bench in years without a Huntron. I feel stupid. The Fluke 867B had that function. Working in the electrical field, I never had to use it. We always pawned electronic problems off on the intstrumentation guys. Now I am stumped.
  11. 76nemo
    Aug 2, 2008
    14
    We have three old Tek curve tracers in storage, but I will admit, I have NO idea how to use them correctly! These are older than me!
  12. hgmjr
    Jan 28, 2005
    9,030
    214
    Depending on how old your old scope was it may not have had automatic horizontal sweep. In that case, you had X-Y sweep by default.
    hgmjr
  13. 76nemo
    Aug 2, 2008
    14
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  15. 76nemo
    Aug 2, 2008
    14
    Back to you tomorrow. Sorry for the double post, hope it gets removed. Let me look real quick, I'll be back after snack,........
  16. 76nemo
    Aug 2, 2008
    14
    2201:
  17. BillB3857
    Feb 28, 2009
    2,402
    348
    It looks like turning the time base fully CCW will give you X/Y.
  18. KL7AJ
    Nov 4, 2008
    2,043
    292
    Lissajous figures are such fun and educational little "toys." I demonstrate them as soon as soon as I introduce AC circuit theory in my classes.
    Most dual trace scopes have the capability of X-Y traces, as well as many vintage scopes. For most Tek scopes, cranking the time base to the extreme left will place you in the X-Y mode. One of the input channels is thus converted to the X channel. The 2250 series scopes had a weird button combination to get into XY mode that I have to "relearn" every time I use them, though!
    Have fun!
    Eric
  19. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Dark Side of the Moon is awesome as well!
