Newbie Here, so please excuse my inexperience and ignorance.
Here is what I am trying to accomplish: Keeping 4 - 1 gal. containers of water from freezing at my cabin. I want to do this because the only to get to my cabin in the winter is to snowshoe in about 3 miles, all going up So I want to reduce the weight of my pack. I am thinking of putting the water in a well insulated cooler with some kind of heat source. Here are the challenges:
1) My cabin is off Grid, the only source of power is a 18 watt solar panel charging a 12v car battery. The panel puts out 0.65 A in direct sunlight. About .006A at 3.46v on a cloudy day. (If my measurements are correct).
2) The average temperature during the winter is around 30F. with lows at night in the 20s.
3) The cabin is in the Central Cascades in WA. Sunlight islimited due to winter cloud cover and short days (as short as 8 hrs. on the winter solstice).
4) I was thinking of using a small 12v. LED bulb (an automobile tail light bulb) as a heat source. This bulb draws about .11 Amps. I think this draw will deplete the 12v battery given the amount of light available.
So, is it possible to do this another way using resistors, a thermostat, light sensor, etc.? Thank you...
-Bill
-Bill
