Can anyone tell me about Liquid Cooling and its use in Cooling down the Switching MOSFET's.
Is the approach necessary or are there any alternates for the same?
Awhile back I tried liquid cooling using a Peltier junction to cool the water. Just mounting the power transistors to the heat sunk of the Peltier worked better. If the thing you are cooling has an irregular surface liquid cooling might make more sense. The cooling power is limited and it certainly does not save any power. If you have open space CO2 cooling might be better.Can anyone tell me about Liquid Cooling and its use in Cooling down the Switching MOSFET's.
Liquid cooling allows the heat to move through a given cross-sectional area faster because it can be physically pumped or otherwise flow (siphon or evaporation/condensation). The heat can be extracted/radiated from the hot liquid many meters away from the heat source.Can anyone tell me about Liquid Cooling and its use in Cooling down the Switching MOSFET's.
.... which would short out all the components?I would use liquid Sodium
I would use liquid Sodium.
No, it is placed inside an aluminum heat sink and temperature gradient allows it to flow in a loop (heated alkali metal rises to the radiator part, cools, then sinks..... which would short out all the components?
