Do they use carbide blades, or standard? Carbide are the type where the chunk of carbide sticks out a bit from each side of each tooth. I've had crappy luck that method on a 12" sliding miter saw (upside down short table saw, essentially)Acrylic cuts fine on a table saw (like a wood circular saw table) and most of those have guides etc to keep it lined up square and cut straight lines at right angles.
A plastic supplier I buy from just table saws the pieces to my dimensions and they come out pretty good!
Standard wood cutting circular saw blades with carbide tips, I've never seen circular saw blades without the carbide tips.Do they use carbide blades, or standard? Carbide are the type where the chunk of carbide sticks out a bit from each side of each tooth. I've had crappy luck that method on a 12" sliding miter saw (upside down short table saw, essentially)
I remember at high school we used to cut a lot of things from sheets of polystyrene using a CAD CAM router and we used solvent for 'gluing' pieces together. Works a dream... just have to be careful not to get drips on the outside of whatever you're making if you're fussy about aesthetics like me!The "glue" is not really glue - it is solvent.
Just like when you are putting a PVC pipe system together, that stuff you put on the joints is not glue, but solvent - it dissolves the PVC on both pieces and "welds" them into a single piece.
I should point out I'm referring to sheet polystyrene plastic, not the expanded packing material. We had it in little containers with a tiny metal dropper. You pressed the bulb and then to apply it you just touch it on and the capillary action sucks it out.Never tried it with polystyrene, but couldn't you use a syringe to apply the solvent? Like when doing Plexiglas/Perspex.
by Jake Hertz
by Jake Hertz
by Robert Keim
by Jake Hertz
