Link Step Failed in MPLAB using P18F4550
Discussion in 'Embedded Systems and Microcontrollers' started by corsair, Mar 19, 2010.
  1. corsair
    Mar 6, 2010
    51
    I'm new to PIC microcontrollers and this is one thing that has been haunting me for a while. I don't understand the cause of this "Link Step Failed" problem.
    I am using the P18F4550 uC, which is wired to a 4-digit, 7-seg display and some switches. This is for a school project.
    The error I am getting after I try to build is as follows:
    Here is my code from APP_Reset to main:
    Code ( (Unknown Language)):
    1. APP_Reset code 0x1000
    2.         goto    main
    3.
    4. APP_main code 0x102A
    5.
    6. main:
    This is inside of my "18F4550.lkr" file:
    1. CODEPAGE   NAME=vectors    START=0x0            END=0x29           PROTECTED
    2. //CODEPAGE   NAME=page       START=0x2A           END=0x7FFF
    3. CODEPAGE   NAME=page       START=0x1000           END=0x8FFFF
    4. CODEPAGE   NAME=idlocs     START=0x200000       END=0x200007       PROTECTED
    5. CODEPAGE   NAME=config     START=0x300000       END=0x30000D       PROTECTED
    6. CODEPAGE   NAME=devid      START=0x3FFFFE       END=0x3FFFFF       PROTECTED
    7. CODEPAGE   NAME=eedata     START=0xF00000       END=0xF000FF
    I've even commented out most of my code, I just don't know what the cause of this problem is. Any help would be much appreciated, and if more information is needed I would be glad to provide it.
  2. corsair
    Mar 6, 2010
    51
    I observed a fault.
    I tried uncommenting my code little by little, and I was able to recover a lot of it. However, when I recover too much, it'll give me the link step failed error- so am I just running out of memory? Is there a way to change this in the linker?
  3. corsair
    Mar 6, 2010
    51
    just in case anyone needs the solution, here it is:
