Linits to Kirchoff's law
Discussion in 'General Electronics Chat' started by rag, Nov 28, 2006.
  1. rag
    Nov 26, 2006
    can anybody help let me know what are the limitations of Kirchoff's law
    Thread moved by moderator - please do not hijack another's post.
    beenthere
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Kirchhoff's Laws can be directly derived from Maxwell's Equations, so it should be no surprise that some imitations are those as imposed by Maxwell's Equations (why shouldn't they be?).
    I cannot see a limitation of Kirchhoff's Current Law (KCL), since it takes account of both the conduction and displacement currents in Ampere's Law (please prove me wrong if I have misinterpreted this).
    There is a limitation of Kirchhoff's Voltage Law (KVL) in the presence of a changing magnetic field, which from Faraday's Law implies a changing electric field which for a closed-loop is not conservative, hence the line integral of the electric field is not zero which is inconsistent with KVL (refer to the integral form of Faraday's Law for an easy way to visualise this idea: ∫E.dl ≠ 0). Additionally, there are issues with the transfer of energy from the magnetic field to the electric field for which a fudge has to be introduced to KVL to make the potential differences around the circuit equal to zero.
    Dave
  3. sci-3d
    Aug 22, 2006
    51
    The only limitation I found of this technique is the number equations. If the circuit is complicated this lead to many equations to solve.
