Lingqi 400 watt inverter shutdown
Discussion in 'General Electronics Chat' started by tonydix, Nov 30, 2014.
  1. tonydix
    May 4, 2010
    23
    I am trying to repair a LINGQI power inverter 800 watt peak and 400 watts continuous. The symptoms are as follows :-
    Connect 12 volt battery gets a brief spark as capacitors charge the a steady 0.2amp on the clamp meter surrounding positive battery wire.
    Switch on and led glows green for about 2 secs ac output voltage begins to rise then the led turns red and alarm sounds. Watching the clamp meter during this process shows an alarming rise in input current to about 30 amps despite the fact that there is no load on the ac output. Clearly something is shorted ! No visible signs of damage to FET's or Capacitors
    Unit has 2 dil chips as control but part numbers are not visible. Any ideas about further troubleshooting. Thanks Tony
  2. Olawalejohnson
    Nov 30, 2014
    dear tony, if its possible u can give a pictorial view of the inverter you are repairing i might help u figure out were the problem is
