Linear Systems question...
Discussion in 'Homework Help' started by Vim0314, Mar 27, 2010.
  1. Vim0314
    Sep 1, 2009
    Hey guys. First time posting, but been reading stuff on here for a while.
    I have attached a scan from my old test and I'm having trouble figuring out part b. Could someone help me figure it out?
    I understand the cap is replaced by a voltage source and the inductor is replaced by a current source. But I am having trouble figuring out the current in the voltage source and the voltage across the current source.
    Thanks in advance!
  2. Ryoshima
    Mar 19, 2009
    I believe that:
    Ic = -20 A
    Vl = 120 V
    Don't think those are right, but they are the results that I obtained. I'll keep an eye on this thread to see if anyone can confirm or deny my calculations.
  3. R!f@@
    Apr 2, 2009
    8,793
    771
    Ryoshima, no one will deny your calculation or Vim0314 for that matter.
    Some one will just confirm the calculations and will let you know if you are wrong or right.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    I have VL(0+)=-54V and IC(0+)=-9A
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    You need to write a loop voltage equation that satisfies the loop conditions at t=0+. Keep in mind that VC(0+)=16V and IL(0+)=4A
    Assume a current I is flowing in the 6Ω resistor - from this and the above information you can write a suitable loop voltage equation with I as the unknown.
  6. Vim0314
    Sep 1, 2009
    I found the answer in the solutions manual and here it is attached...
    In blue I boxed in the correct answers I am looking for. But in yellow I have circled where I have a problem. Can someone explain to me how they figured out the Ir1? and how a 24 magically appears?
    thanks
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    One could write ..... somewhat laboriously ......
    VR1+VR2+VR3+48=0
    IR1*2+16+IR3*6+48=0
    IR1*2+16+(IR1-4)*6+48=0
    IR1*2+16+IR1*6-4*6+48=0
    IR1(2+6)+16-24+48=0
    IR1(2+6)=-48-16+24
    IR1=(-48-16+24)/(2+6)=-40/8=-5
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Rather than hijack a thread it's better for all concerned if you start a new thread.
    Keep in mind also the expectation that homework forum posts will show an attempt at solving the problem.
