Hmm that is a pretty small force I think.
So basically any solenoid would do right?
This is a very important specification that you should have stated way back in post #1. With this in mind, I now recommend using a bi-directional pneumatic or hydraulic cylinder, controlled by a solenoid valve..... Mike can you give me a ling to one of these motors? Are they fast? I need a fast one since I will use it to change gears in my kart (0.2 - 0.3 sec)
The thing is that the pneumatic and hydraulic cylinders have to be actuated by some sort of pump/compressor right? I don't have the space to put that on my kart.This is a very important specification that you should have stated way back in post #1. With this in mind, I now recommend using a bi-directional pneumatic or hydraulic cylinder, controlled by a solenoid valve.
Starter solenoids (the big one attached to the side of an automotive starter motor that push the drive gear into the ring gear) have more than enough force, but their throw is too short, and besides, they take a huge amount of current. If the OP doesn't have room for a vacuum or pressure pump, he likely doesn't have room for a large automotive battery, either...Would a starter solenoid be the trick here?
No room for a car battery. At most i can use a scooter battery.Would a starter solenoid be the trick here?
by Duane Benson
by Aaron Carman
by Robert Keim
by Aaron Carman
