Linear Servo Help Sought
Discussion in 'General Electronics Chat' started by roger-c130, Jan 19, 2007.
  1. roger-c130
    Jan 19, 2007
    If you're familiar with Radio Control servos I would like to ask your help with a
    need I have regarding same. I would prefer to communicate via Email if OK by you.
  2. sci-3d
    Aug 22, 2006
    51
  3. fanie
    Jan 20, 2007
    63
    I agree - one gets too many e-mails, and not enough time to handle them !
    You can still ask in such a way your app is not in jeopardy if you think someone may use your idea...
  4. roger-c130
    Jan 19, 2007
    Thanks for your responses. Many years ago, I owned an R/C set that used linear servos and the system worked quite well. I now have a need for the same type of servo but I need more travel. Those old servos utilized a wire wound resistor over which a feeler arm slid back and forth to control the positioning. I wish to do the same but with longer travel. So, my thinking is to disconnect the servo's pot and replace it with a wire wound one. Commercial units are far, far too expensive for my use. So, questions are this:
    1. Can make my own wire wound resistor?
    2. What materials (wire and core) to use to keep the resistor less than 1/4" d.
    3. Would I need to make any other alterations electronically?
