Transformer -> bridge -> cap -> linear voltage regulator
Ah, the all-discrete, positive linear voltage regulator; no LM3xx parts, but maybe a 723 at it's core. Built a few, repaired a bunch. Sticking to the basic regulator, without goodies like current limiting and regulation down to 0 V, there are two basic circuit topologies:
1. Fixed reference voltage, variable gain. This usually has the output adjustment pot in the feedback voltage divider.
2. Variable reference voltage, fixed gain. This usually has the output adjustment pot across the reference diode, and fixed resistors in the feedback voltage divider.
I'm asking for experience-based opinions on the advantages and disadvantages of each circuit type. As a sub-question, which is more advantageous for a bench-type supply with a large output voltage adjustment range, as opposed to an industrial or application-specific supply with a narrow adjustment range like +/-10%.
Thanks.
ak
Thanks.
ak
