Linear regulator with a pass transistor protection.
ronv
Joined Nov 12, 2008
3,770
So if i'm willing to sacrifice my output voltage to 24V (2x12) i will get away with the power dissipation? For example if i set the output voltage to 10V total and im drawing 2.5A the power dissipation will be split between the two regulators and it will be for each regulator Vin from the transformer about 15V - 5V output = 10V*2.5A = 25W is that right ? I think my idea is wrong here.
this circuit isn't mine. My transformer is 2x12VAC.
Yes, I think it is as you say. It also has the added advantage that when you need low voltage the regulator only has to drop the voltage from 12 volts instead of 24 so the normal power is lower. The secondary of the transformer must be separate as you have shown.
Ps. You probably won't be able to get quite 24 volts DC from the 24 transformer because of some e drops - but close.
