(All comments apply to a lateral FET in an IC, not a vertical power FET)
You have 4 terminals you're looking at:
Gate
Source
Drain
Bulk
Usually the bulk is tied to 0. Let's say the source is also 0.
Vb = 0
Vs = 0
To turn the NMOS on you apply a positive Vgs.
That gives you:
Vgs = Vg
Notice that the FET is symmetrical though, the source and drain are the same thing.
When you apply a Vd, you get:
Vds = Vd
Now, look at the gate to terminal voltages:
Vgs = Vg
Vgd = Vg - Vd
Vgd is smaller than Vgs.
Electric field is voltage / distance.
The distances are equal from gate-to-source and gate-to-drain
This gives you much weaker electric field between gate and drain than gate and source.
This means the channel is larger at the source than at the drain.
