Linear Power Supplies..why 2 or 3 smoothing caps ??
Discussion in 'General Electronics Chat' started by ranatungawk, Nov 10, 2015.
  1. ranatungawk
    Thread Starter Senior Member
    Oct 30, 2008
    147
    On Linear Power Supplies, i have seen two or three 1000uf capacitors are used parallely (just after the bridge rectifier) as smoothing caps instead of using one 3000uf capacitor. Has it been designed so purposelessly ? or no special reason (are 3 x 1000uf slimier to one 3000uf)?
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    might have been for size.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Or the builder had lots of 1000uF capacitors on hand...;)
  4. wayneh
    Sep 9, 2010
    12,390
    3,245
    In other words, there's no secret advantage to multiple caps in parallel, versus a single cap. The equivalent series resistance and heat dissipation would be very slightly better for multiple caps, so it's remotely possible the 1,000µF caps were a cheaper or easier solution than choosing a single cap that was properly rated for the job.
    I expected from the title that this question was going to be about using different types and values of caps in parallel, such as a big electrolytic and a 0.1µF ceramic. This is about filtering different frequencies more effectively. Electrolytics are too slow for high frequency filtering.
    ranatungawk likes this.
