Linear optocoupler
Discussion in 'General Electronics Chat' started by karas, Oct 3, 2016.
  1. karas
    Thread Starter Active Member
    Sep 8, 2011
    129
    Is there is another cheapest way instead of using linear optocoupler like il300 and do the same function
  2. 64C113M Abe.
    Sep 13, 2016
    14
    How about, Led attached to a photocell via a heat shrink tube?
  3. karas
    Sep 8, 2011
    129
    I need to be linear
  4. ronv
    Nov 12, 2008
    3,403
    1,477
    karas likes this.
  5. crutschow
    Mar 14, 2008
    13,505
    3,379
    Here's a little blurb I wrote on that very subject.
    Sensacell, ronv and karas like this.
  6. karas
    Sep 8, 2011
    129
    Is this ok if I use it to sence the voltage feedback, it will be very fast response to the input
  7. karas
    Sep 8, 2011
    129
  8. crutschow
    Mar 14, 2008
    13,505
    3,379
    I have no idea.
    What is "very fast"?
    What are you trying to do?
    What signal are you trying to send through the opto?
  9. karas
    Sep 8, 2011
    129
  10. karas
    Sep 8, 2011
    129
    I need to sense the voltage feedback , that why I need the sensed voltage linear and fast response
  11. hp1729
    Nov 23, 2015
    2,105
    235
  12. Sensacell
    Jun 19, 2012
    1,184
    277
  13. crutschow
    Mar 14, 2008
    13,505
    3,379
    That tells me nothing useful.
    Is "fast" milliseconds, microseconds, nanoseconds, picoseconds...?
    Sense voltage feedback from what?
    Please answer my questions in post #8 if you want any further help.
    Post a diagram of what you are trying to do.
    You lack of more specific information makes it impossible to help you further. :rolleyes:
  14. Bordodynov
    May 20, 2015
    673
    194
    See
    blocco a spirale likes this.
  15. hp1729
    Nov 23, 2015
    2,105
    235
    Over what range do you need linearity? Input voltage, output voltage, current, resistance? You might find something with a workable region.
  16. crutschow
    Mar 14, 2008
    13,505
    3,379
    That also uses a specialized opto isolator which the OP wants to avoid.
  17. karas
    Sep 8, 2011
    129
    Sorry Crutschow,
    This basically DC DC bidirectional ,the input to the primary is 40-100VDC and the output from the secondary is 500-1000VDC ,the switching frequency is 65Khz ,i need to sense the output voltage from the secondary side, the control is in the primary side,
  18. karas
    Sep 8, 2011
    129
    Can i get the LT spice model for the linear opto coupler HCNR200, is this you create it or you download it?
  19. Alec_t
    Sep 17, 2013
    5,977
    1,136
    The model can be found here.
    karas likes this.
  20. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    Its described in some appnotes - you need 2 optocouplers; one is your isolated signal path, the other is the feedback loop controlling the op-amp driving the IRLEDs. The 2 IRLEDs are in series so they carry identical current.
