Linear Mode 1000w Discharger prototype keeps popping fets
Discussion in 'The Projects Forum' started by magudaman, Feb 27, 2012.
  1. magudaman
    Feb 27, 2012
    31
    So I am trying to build a serious discharger for testing batteries and battery packs from 2.0V to 80V and currents up to 250 amps (limited by wattage). Sticking with the design of many commercial dischargers I wanted to start by trying to do MOSFET driven in its linear region.
    Through some other forums I was given a circuit diagram put together for a magazine article a while back for a simple constant current discharger. From that circuit I came up with this circuit:
    The circuit is run by 10V. In the non inverting input I have a 0-5V that controls the level of current. On the inverting input I have the current sense from the 0.02ohm resistor. This all dumps out into a FET that will burn off as much as 100 watts.
    So this circuit during testing didn't have the .1uf capacitor to begin and seemed to be working great at 3.7, 13v all the way up to about 30V but as soon as I hit around 40 volts POP! the fet fails. I hooked up a scope to find a nasty oscillation that seemed to be causing quite a bit of inductive voltage:
    13.3V battery at 7 amps:
    So I added that 0.1uf capacitor and everything went perfectly flat and back to DC
    So I thought I had fixed the problem and tried a 60V source: .2 amps, .4 amps, .6 amps POOOOFFFFF!!!! Darn
    So of course I didn't have the scope recording during the failure so I really have no idea what happened. Even DC mode the fets should be good to 5 amps @ 60V peak. My current current sensors never see any peaks and seems to be very steady.
    FET:
    Alpha & Omega Semiconductor Inc
    100V 150A AOT410L
    .45 C/W
    http://aosmd.com/res/data_sheets/AOT410L.pdf
    OP AMP:
    Texas Instruments TLV2371IP
    Rail to Rail input and output
    http://www.ti.com/lit/ds/symlink/tlv2370.pdf
    So I know there isn't a lot of information here but do you think this is the FET not up to the task? Or is my circuit not reacting fast enough as the voltage gets higher and just start pulses high current? Other possibilities?
  2. #12
    Nov 30, 2010
    16,660
    7,305
    Look at the "safe operating area" graph of the MOSFET.
  3. magudaman
    Feb 27, 2012
    31
    Yah that what I was quoting when I said would be safe for a peak of 5 amps @ 60 volts but here it is anyhow:
  4. #12
    Nov 30, 2010
    16,660
    7,305
    I guess that's not the problem. Anybody else care to try?
  5. magudaman
    Feb 27, 2012
    31
    Far as we know, I still wonder about these cheaper Alpha and Omega Fets though, before I give up completely I am definitely going to try another FET and manufacture. I might just try a 200V fet just to be safe. In fact the 200V fet for almost the same price has an even better .3 w/c rating and still can do 25 amps 2 volts
  6. crutschow
    Mar 14, 2008
    13,469
    3,356
    The next test have the oscilloscope connected and monitor the transistor as you increase the current.
  7. jimkeith
    Oct 26, 2011
    539
    99
    What are you using for a heatsink?
    Tj = 5A * 60V * 0.45°C/W + 25°C = 160°C (assuming an infinite sink)
    Unless you have an exceptionally good heatsink, you may be simply frying the device.
    Anytime I have done this sort of thing, it took many cells in parallel to obtain reliability.
  8. magudaman
    Feb 27, 2012
    31
    This was just the maximum the fet could handle, I never intend on exceeding 100 watts at any given voltage. So at 60V I wanted to achieve 1.6 amps. My heat sink was cold at the start of that test so around 20c and didn't even get a chance to warm up the mass of the sink.
    My 1000w sink is about .07c/w; that's with forced cooling of course
  9. magudaman
    Feb 27, 2012
    31
    Agreed, only one FET left now so I was trying to see if there was anything else I needed to try before frying that last one :(
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    I think you need some compensation from the output of the op amp back to the inverting input. The op amp is probably still oscillating.
  11. THE_RB
    Feb 11, 2008
    5,435
    1,305
    And increase the value of the resistor, you gain in safety as the resistor will dissipate more and the FET less, and the increased voltage on the resistor gives better feedback and better stability.
    And heatsinking is good! I bet if you posted a photo of your heatsink (where you killed the FET at 60v 0.6A) people would criticise its size... ;)
  12. Ron H
    Apr 14, 2005
    7,050
    657
    I agree. The gate resistor and capacitor add a pole in the loop, in addition the the op amp's pole. This is why it was unstable. Adding the 100nF cap pushes the external pole to a lower frequency, but probably not far enough to overwhelm the internal pole.
    Try changing the gate resistor to 100Ω, and the resistor in the feedback path to 10k. Add 100pF from op amp output to inverting input.
    EDIT: I didn't make it clear that you need to omit the cap from gate to GND.
  13. magudaman
    Feb 27, 2012
    31
    Alright did some more testing today. I started to reverse engineer the retail discharger device (CBA) to look for more ideas. So taking from their cues I added a .1uf and 10uf capacitor on the gate of the FET with a 10K ohm resistor from gate to ground. I also added a .1uf resistor from the sense line to ground but ended up removing it as it was causing a nasty oscillation.
    So I put the new FET in with my new caps and tested the circuit at ~60V. I slowly increased the current and everything looked extremely smooth. I hit one amps started to get excited and then POOF again. No go. At least I recorded this on this time.
    As you can see I am not getting any oscillations or peaks right up to the point it blows up. Then all the sudden the op-amps decided to increase the voltage by ~3 volts and then detects the crazy amount of current, decreases but it is already too late. It's interesting you can actually see it takes around 25 milliseconds for the fuse to pop.
    Here is a close up of the problem area:
    Other interesting facts that still have me wondering about fet choice...the retail discharger device I have is rated to 55 volt yet they used a 100v fet. Again I intend on using 200v if I can get this working because of the price, better DC performance, and .3c/w junction to case. I still wonder if I am over a threshold for some reason and going into a sort of avalanche condition and the op amp can't react fast enough.
    Other consideration my op amps slew rate is 2.2v/μs and the retail unit slew is 5.5v/μs. Maybe my unit can't keep up?
    I have to give the ideas above some thoughts too. I gotta order some more FETs and get this thing figured out before they arrive.
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Photo of heatsink?
  15. shortbus
    Sep 30, 2009
    4,086
    1,665
    Unless I'm missing something here or something is missing in the schematic shown in post #1. Where is your gate driver? This is a classic 'high side switch'. As the source voltage goes up the gate voltage is no longer high enough to put mosfet in the active mode. It will be in the 'linear' range of conduction, basically a resistor, and a low wattage resistor at that.
    To change the circuit to a 'low side switch' and not need a gate driver, connect the ballast/dropping resistor to the mosfet drain terminal and the source to ground.
  16. Ron H
    Apr 14, 2005
    7,050
    657
    The transistor is not operating as a switch. This is a classic current sink. It is a completely analog circuit.
  17. shortbus
    Sep 30, 2009
    4,086
    1,665
    OK, I missed that part. But doesn't the gate voltage still have to follow the same Vgs parameters? As I understand it, a Jfet is more suited for this type of circuit, because they are made for a linear application where a Mosfet should be used for a switch.
  18. Ron H
    Apr 14, 2005
    7,050
    657
    MOSFETs work fine in analog apps. Some linear (analog) audio amps use them as output stages.
    Power JFETs are a rare breed. Here is one manufacturer. There may be others.
  19. Ron H
    Apr 14, 2005
    7,050
    657
    Magudaman, here is a simulation of your compensation scheme (as I understand it), and mine. I couldn't find a spice model of your MOSFET, so I picked one that is similar, except for breakdown voltage.
    I know you aren't pulsing the input, but simulated pulsing is a good way to expose instability tendencies. Note that your simulated scheme doesn't oscillate, but it is very close to it. My scheme is extremely stable, at least in simulation.
  20. bountyhunter
    Sep 7, 2009
    2,498
    507
    Then your current limit loop is too slow. Maybe you have a pole that slows it down. But, any current limiter has to be fast enough or things blow up.
