Linear Equation using opamp; 0.4 to 3.6 V FSR to 0-3.3V scalling circuit
Discussion in 'General Electronics Chat' started by Manjunath CV, Sep 25, 2008.
  1. Manjunath CV
    Sep 25, 2008
    want to convert an output of one of the module whose full Scale Range is 0.4 to 3.6V ... this needs to be scalled to FSR 0 to 3.3V ... when corellated this gives a linear equation Vout = 1.03125 * Vin - 0.4125, i can use the VCC to be between 4 to 5V, how can this be implemented using Opamps. with an error budget of 20mV max
    Rgds,
    Manju
  2. scubasteve_911
    Dec 27, 2007
    1,202
  3. mik3
    Feb 4, 2008
    4,846
    63
    If you want to minimize the offset errors then you have to use precision op-amps. They are designed to have low offset voltages. Also, for better results use resistors with an accuracy of 1% or less.
  4. scubasteve_911
    Dec 27, 2007
    1,202
    Using 1% isn't even going to help him.. His total 'error budget' is 20mV. Due to gain error alone, assuming about a gain of 1, he can be off my 2% not assuming anything else. (2 resistors, each going away from eachother), 2% of about 3V is 60mV.
    He needs 0.1-0.2% resistors with good tempco if he wants accuracy over range. This is just one factor for a circuit like this.
    Steve
