Linear circuit KCL help- EASY
Discussion in 'Homework Help' started by caliendo, Mar 26, 2009.
  1. caliendo
    Mar 26, 2009
    Hey guys I have a test tomorrow and this is my first time to post here so thanks for the help!
    Heres the question, I just have to find V0 and Vs. Here is the answer sheet to the problem, what I don't understand is why is the node 3V0 and why across that resistor is it 2v0? Thanks for the help guys.!
  2. Ratch
    Mar 20, 2007
    1,068
    caliendo,
    Sure, it's easy. Vo is 2 volts. 2 volts across a 1k resistor is 2 ma. That same 2 ma goes through the 2k resistor to make 4 volts = 2Vo across it. So 2 volts from Vo plus 4 volts from the 2k resistor makes 6 volts, which is 3 times Vo.
    Ratch
  3. caliendo
    Mar 26, 2009
    doh! that is easy! thank you so much!
