Linear Circuit Help needed
Discussion in 'Homework Help' started by Albinoswordfish, Sep 4, 2007.
  1. Albinoswordfish
    Sep 4, 2007
    5
    Hi I'm stuck on this one problem I have for my linear circuit analysis class.
    Right now I'm very confused on the affect a dependent source has on a circuit
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Where do you get hung up in solving the problem?
    Can you show us what you have tried in the way of solving the problem?
    hgmjr
  3. Albinoswordfish
    Sep 4, 2007
    5
    well I tried using current division to do the problem because the dependent current source and two resistors are in parallel. However the dependent source doesn't have a resistance across of it so current division doesn't work. I can't use voltage division because the resistors and dependent source are not in series.
    Basically we just covered current division and voltage division in class, but can't see where to use it.
    So now I'm stuck
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    It is getting late so here so I will have to signoff. I am certain another member can provide you with some helpful hints to get you a little closer to the answer.
    Good Luck,
    hgmjr
  5. techroomt
    May 19, 2004
    198
    i admit i have no idea what the diamond shaped device is on the right "g sub m". the given value is 0.2 mS, is that milli-Siemens? i assume one power source Is Vs ?!?
  6. Distort10n
    Dec 25, 2006
    429
    It is a dependent current source. Unfortunately, I never did much with dependent sources in class. I believe the dependent current source is controlled by the current through the indepedent source, so it is a CCCS. Current Controlled Current Source.
  7. JoeJester
    Apr 26, 2005
    3,401
    1,218
    It looks like a voltage controlled current source to me.
  8. recca02
    Apr 2, 2007
    1,211
    the worst thing is superposition is supposed to not work (or atleast the way it is to be applied is different) in these cases. i have done similar examples before but now sadly have forgotten the approach for it(plus my ol' book went missing,it was the book i studied from). i m also not able to figure out the meaning of equivalent conductance as seen by current(does it mean the parallel branches of the dependent current source and the resistances?).
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    One way to tackle this problem is to apply Norton's Theorem. Review the material pointed to by the link or review any information in your textbook on Norton's Theorem.
    The circuit contains two current sources in parallel with a resistance across them made up of R1 and R2 in series. The current sources are Is and gm*Vx. Use Norton's Theorem to write the equation for Vs based on the current sources and resistors and then see if you work out the answer from there.
    If you get stuck tell us where you are stuck and we will try to help you advance beyond the sticking point.
    hgmjr
  10. JoeJester
    Apr 26, 2005
    3,401
    1,218
    Albinoswordfish,
    The Req is given. Use that to your advantage.
