Linear CCD Slit Scan Camera ?
Discussion in 'The Projects Forum' started by Mustafa Umut Sarac, Jun 19, 2010.
  1. Mustafa Umut Sarac
    Jun 19, 2010
    Hello ,
    This is my first mail to forum and I want to present my best.
    I want to build a camera which will have to have a linear ccd array , its cell powered small breadboard with memory .
    The lens would be a slit and camera will be used handheld to make a experimental photograph which will be sliding cars , people or buildings.
    I want to have parts which might be very cheap and ccd array lenght is 30 mm or longer. Color and largest memory and USB is preferred.
    I dont want to solder anything and want plug and play.
    Cost less than 35 dollars.
    Is it possible and from whom ?
    Thank you ,
    Mustafa Umut Sarac
    Istanbul
  2. sceadwian
    Jun 1, 2009
    499
    37
    Your best bet would be to take a handheld scanner, the type that your roll across documents and modify it.
    http://www.zonezero.com/zz/index.ph...-brew-digital-camera&catid=5:articles&lang=en
    Might provide some ideas.
    The optics would be the hard part. Those types of scanners are meant to take pictures of close up objects so it would be completely in your care to design a lens system that it would work with.
  3. retched
    Dec 5, 2009
    5,201
    313
    There was an instructable or maybe just a blog post on a few guys who made a 3D laser scanner.
    They used a wine glass stem to make a vertical line laser from a standard laser pointer, then wrote some software to take video cameras CCD input and convert it to 3D files for use in 3D output devices.
    Maybe you can use something from that.
    [ed]
    Ok, I cant find the one I was talking about, but here is something REAL cool. Instead of moving the camera slit, the camera stays still and you move the laser. That would be real easy.
    If you have a red, green, and blue laser, you could make a color 3D image. I dont know if this can help you, or maybe get you in another direction, but you can do it for your 35 dollar budget. A $10 or less webcam and a $20 dollar laser level.
    The software is free.
    http://homebiss.blogspot.com/2009/02/diy-3d-laser-scanner.html
    [/ed]
  4. sceadwian
    Jun 1, 2009
    499
    37
    Not even close to what he's looking for retched. What he's talking about works like the photofinish camera at horse racetracks, it's very different than normal photography. It's a narrow slit and it can only photograph things moving across the cameras field of view. If you moved the camera instead you'd be taking a photograph of a stretch of time not an individual moment.
  5. retched
    Dec 5, 2009
    5,201
    313
    Ahh. Well, you never can tell. My getting the image into a vector environment, measurements and such would be much easier to gather.
    Even if he wanted to use that to make the model then use a standard CCD to make the texture map.
    Its all I had.
    And he said experimental, for buildings people and cars. So it may be helpful.
    I guess we will see if the OP returns.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    At one time around WWII, slit cameras got some use. One problem is that the film speed and the camera motion had to be exactly the same. If all went well, you could get a 1000 foot record of what had been under a photorecon aircraft in amazing deatail. Then the planes got shot at, and pilots got less interested, or something.
    With a CCD scan, it might take some DSP to make an unblurred image.
  7. sceadwian
    Jun 1, 2009
    499
    37
    With the hand scanners there's a wheel on the bottom of scanner which controls the actual data acquisition speed of the scanner, all you'd have to do is interface with that wheel mechanically to say a fixed tripod and then precise motion isn't necessary. Hand motion can be quiet variable which is why hand scanners use the wheels. As I said it's an out of the box instant solution. IF you can redesign the optics of the handscanner to refocus it, you don't even need software, you can use the stock TWAIN driver for the scanner..
  8. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I can't find them now, but I had come across a couple of sights where people used flatbed scanners to capture images. So that's my suggestion, an old flatbed from the local junkyard. And if you like bulk, look for an old fax machine, but I don't recall any doing color.
