linear amplifier
Discussion in 'General Electronics Chat' started by praondevou, Oct 18, 2012.
  1. praondevou
    Thread Starter AAC Fanatic!
    Jul 9, 2011
    2,936
    489
    I want to amplify an AC signal 100Hz 10Vpp to 60Vpp. Small component count and low input offset voltage (less than 1mV) are desirable. Output current has to be at least 200mApp.
    I've seen Opamps from APEX, but they cost more than $120. Is there a cheaper option? Building a circuit from zero will take too much time.
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    Look at LM675 or LM1875.
    praondevou likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Take a look at the LM3875 audio opamp:
    http://www.ti.com/product/LM3875
    It can work upto 90 Volts and have an output current upto 6A.
    The offset is about 10 mV.
    Bertus
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    An LM3886 50W audio amplifier IC with a plus and minus 35V supply or a single +70V supply can easily produce 60Vpp into any load from 8 ohms to infinity.
    Two resistors set its gain but a gain of 6000 at 100Hz might need an additional cheap opamp as a preamp.
    Your requirement of the very low offset voltage will need trimming.
    It costs only $6.72US each at Digikey today. They have 4183 of them in stock today and can get 40,260 more in a couple of days.
  5. crutschow
    Mar 14, 2008
    13,520
    3,386
    Why do you need low input offset if the signal is AC? Just AC couple the output if you want zero offset.
  6. praondevou
    Jul 9, 2011
    2,936
    489
    Ok, the audio amplifiers is something I can have a look at.
    However, this circuit is used to demagnetize/magnetize iron core toroids with a controlled waveform inside a Helmholtz coil. So an offset is really not useful.
    Maybe more important than a low offset is a low offset voltage drift. Once adjusted it had to be stable.
    Thanks all.
  7. praondevou
    Jul 9, 2011
    2,936
    489
    The load is a coil. The input is a sinewave that looks like this:
    There is an interruption somewhere in between. Vpp max is 10V. Vpp min is 1mV (1:10000).
  8. kubeek
    Sep 20, 2005
    4,691
    806
    You could build a discrete audio-type amplifier, because +/-60V is getting a bit too much for integrated solutions. Because the current is so low, a capacitor in series should help with any offset that might be present, or you can make a DC servo amplifier to null the offset automatically.
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    No.
    He asked for a max of 60Vpp, not +/-60V which is twice as much as he wants.
  10. kubeek
    Sep 20, 2005
    4,691
    806
    You´re right Audioguru, the classical Vp vs. Vpp mixup :D
  11. praondevou
    Jul 9, 2011
    2,936
    489
    Why does this configuration oscillate?
    It starts oscillating with increased load (without a load/ a small load it works perfectly up to 20kHz square wave). However with a 20Ohm load it starts oscillating at a very high frequency (some MHz as far as I remember) even with a 100mHz sine wave. Obviously there is some undesired phase shift, adding caps in the feedback loop only worsens the problem.
    http://www.ti.com/lit/ds/symlink/opa454.pdf
    http://www.onsemi.com/pub_link/Collateral/D44H-D.PDF
    http://www.onsemi.com/pub_link/Collateral/TIP29B-D.PDF
    Adding base resistors or base-emitter resistors to the TIPs doesn't make a difference for the oscillation issue.
    A simple npn/pnp at the output does work, but I want more amps therefore the darlingtons.
  12. kubeek
    Sep 20, 2005
    4,691
    806
    Shouldn´t there be some bias resistors for the TIPs?
  13. Ron H
    Apr 14, 2005
    7,050
    657
    With no load, the TIPs don't draw enough current to turn on the D44/D45 parts, so the TIPs just act as emitter followers. With load, the Sziklai pairs are active, and are feedback loops. If both transistors in a Sziklai pair have Ft's that are around same order of magnitude, they may oscillate, independent of the circuit driving them.
    Try decreasing the 2k resistors to around 100Ω and see if that helps with the oscillations. Note that the D44H11 and D45H11 will not begin to turn on until load current exceeds about 6mA.
    I don't see why you don't just use the D44H11 and D45H11 as emitter followers. They have minimum betas of 60, and the op amp can put out ±50mA. That should reliably drive out ±1 Amp.
    Or, as others have said, use an audio amp with series capacitors to eliminate the offset.
  14. praondevou
    Jul 9, 2011
    2,936
    489
    My mistake. I should have started a new thread. It's the same signal but for a different application. Now current will be up to 4A at +-40V.
    That's why I thought using the darlingtons is a good idea.
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    The transistors are not biased so they cause severe crossover distortion which probably triggers the oscillation. Bias the transistors properly then maybe they won't oscillate.
  16. praondevou
    Jul 9, 2011
    2,936
    489
    Why do they not cause any crossover distortion at lower input signal amplitudes and/or higher load resistance?
  17. Ron H
    Apr 14, 2005
    7,050
    657
    At 100Hz, 1.4V of crossover distortion at 13V/usec (the op amp's slew rate) is probably not going to be visible on a scope.
  18. praondevou
    Jul 9, 2011
    2,936
    489
    Hum, I'm gonna implement your recommendations tomorrow.
    I went down to 100 mHz(!) and it still oscillates, not starting at zero crossing. On a sinewave it starts at a certain voltage level with maximum amplitude (superimposed on the sinewave) and then decreases when the voltage goes towards zero...
    If I'm not getting it to work tomorrow I'll post some oscillographs.
    Thanks all
  19. praondevou
    Jul 9, 2011
    2,936
    489
    Lower resistances from emitter to base (100R) made things worse.
    The oscillation starts when reaching a certain voltage level, at about 600mV at the base of the D44/45H11s, so apparently when they start to conduct. The oscillation occurs on both sides, below is showing only one side with a small input signal.
    It does work without oscillating when I put 1nF caps from base of the D44 and base of the D45 to their collectors.
      File size:
      21.9 KB
      32
      File size:
      25.9 KB
      30
