linear amplifier current and voltage question
Discussion in 'General Electronics Chat' started by saviogee, Mar 19, 2010.
  1. saviogee
    Mar 10, 2010
    Why does the collector voltage in a linear ac amplifier decrease when the collector current increases?
  2. studiot
    Nov 9, 2007
    5,005
    515
    The collector voltage is measured relative to zero, so the statement ' the collector voltage falls' means that the voltage of the collector drops towards zero.
    This must increase the voltage across the collector load resistor which is connected between V+ (the voltage rail) and the collector.
    By ohms law this increases the current in this resistor. This current also flows through the transistor.
  3. saviogee
    Mar 10, 2010
    Thanks alot for your help!
