Linear actuators
Discussion in 'The Projects Forum' started by Adamhumbug, Mar 5, 2014.
Thread Status:
Not open for further replies.
  1. Adamhumbug
    Mar 5, 2014
    Hi all, I will start by saying I know very little about electronics so please be as basic as you can be with your kind responses. Also when referring to products if you could give an example of what I need that would also be appreciated.
    I am wanting to build a circuit maybe using linear actuators, that would be capable of lifting a small screen up and forward.
    Basically I want to hide the screen and when power to the circuit is turned on the screen will move up from its hidden position and move forward flush to the hole.
    What I would like is a guide in how I could make this happen.
    Many thanks
    Adam
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Hiding the automotive requirement does not help you:
    Hiding a head unit in a corsa
    Bertus
    PS when you try a third time a ban will be given.
Thread Status:
