Linear Actuator help-How to run a loop?
Discussion in 'The Projects Forum' started by rjburton, Aug 7, 2014.
  1. rjburton
    Aug 7, 2014
    9
    I'm new to electronics and have a project that requires my linear actuator to go fully in and fully out in a loop once its started and loop for 2 hours rather than using a rocker switch to reverse polarity. Is there a simple way to do this? Just to clarify I want to turn on the power and have the actuator go fully in and fully out automatically in a loop for 2 hours.
    Any help is appreciated!
    Rob
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    A bit more info needed. First do you have a link to information on your actuator?
    Ken
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    If the actuator has end limit switches you can just use those to energize/de-energize a single relay to change polarity.
  4. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    ....and a two hour timer to end the process.
    Max.
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
    yes.. thanks..
  6. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    Of course if there is a little more to it, a Smart Relay may be in order, I see you can get an IDEC on ebay for e.g. for around $60.00 which is around the price of a timer itself?
    Max.
  7. inwo
    Nov 7, 2013
    2,435
    315
    +1
    From another project.
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    Couple of issues:
    1. Is the actuator rated for continuous operation?
    2. Reversing power a motor running full speed is a good way damage it.
    Ken
  9. rjburton
    Aug 7, 2014
    9
    The actuator is a 12 inch stroke at standard speed (1 inch per second) with feedback. I bought a 3 position rocker to allow out, stop, and in. It does automatically stop at the end of each end i.e. fully out and fully in it shuts down. I think it has a rest period but I'll put a pic of the unit later today as I'm not sure what other info is on it. I bought two used ones on EBAY a couple years ago.
  10. Alec_t
    Sep 17, 2013
    5,979
    1,138
    What power supply does the actuator require?
    What control signal does it expect?
  11. rjburton
    Aug 7, 2014
    9
    I use a 12v battery and have a 12v 6amp power supply on the way.
  12. rjburton
    Aug 7, 2014
    9
    The information on the Actuator says:
    Type: S-12V-A1 - 300(P6212)
    Power Rating: DC 12V
    Stroke: 300mm
    S/N:
    Made in Taiwan
    Motor: BU/ GR/ +5V Gnd Sensor RA/ BL/ YE/
  13. mcgyvr
    Oct 15, 2009
    4,791
    976
    Got a link to a datasheet or other specs on the actuator..
    That type # isn't bringing up anything useful for me
  14. rjburton
    Aug 7, 2014
    9
    Unfortunately no. It is similar to one on ebay with this title
    (2) 12" Power Linear Actuators trunk tonneau street rod
    however I know "similar" is not appropriate in these types of situations. Since I got it used it came with nothing.
  15. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    Appears to have a built in potentiometer for position?
    Max.
  16. rjburton
    Aug 7, 2014
    9
    The only thing I know for sure is what is says on the unit and that it is a 5 wire set up which allows feedback.
    Sorry I don't have more information...
  17. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    I would hazard a guess that two is for the motor and three is for the pot.
    Sounds like the pot was fed from 0 to +5 and the slider went to some kind of logic sensor input?
    Max.
  18. inwo
    Nov 7, 2013
    2,435
    315
    I think a current sensing design is possible, using the internal limits, with no other feedback.
    Haven't had time to draw anything.
    If not the internal limits could be brought out to delay relays.
  19. rjburton
    Aug 7, 2014
    9
    Your help is most appreciated!
    I feel a little like I'm in a foreign country and only know how to ask were the bathroom is :D
  20. inwo
    Nov 7, 2013
    2,435
    315
    Not getting anywhere on current sensing.:eek:
    Can you access the internal limit switches, and bring the leads out for control?
