I hate to ask such a simple question of you all, but I can grasp answer.
First: stanley gate actuator, 12 DC
Second: the actuator has 5 amp microswitches to limit the travel
Third: I am using the acuator to power my solar tracker.
I have gone to:www.beam-wiki/using_limit_switches, but I still can not see throught the circuit.
The actuator has the following wire location in the motor box: Motor +, Motor -, Com, Ret and Ext. The microswitches are spdt, motor is rated at 3 amps@12 volts. I have room to install relays to handle most any amp spike.
Thanks for any help
Silvergoose
Thanks for any help
Silvergoose
